Page 4 of 4 FirstFirst ... 2 3 4
Results 31 to 33 of 33
Thread: LS6 heads or cam
  1. #31
    Personally, I would suggest Comp Cams 918 springs and hardened pushrods but it's your money.
  2. #32
    The stock pushrods are soft material and bend very easily if you ever float the valves. High RPMs lead to bent pushrods quite often. Numerous LSx engines fall victim to bent stock pushrods. The stock rocker arms will be fine.
  3. #33
    Mar 2007
    I INSTALL HEADS AND CAMSHAFT LS6, DOES NOT CHANGE THE PUSHROD AND THE OPERATION IS PERFECT, IS AMAZING THE PERFORMANCE
