I took the iac out and blocked the port it came from. I wanted to see if the pcm would control it. Started it up and the iac never moved. I tried two new iacs and nothing. I would expect them to move trying to reduce idle air.
I figured out that tge iac never moves. I have put 2 brand new ones in it. I can pull the iac out abot halfway and it will idle ok. But it will nearly die when i put it in gear. Maybe bad pcm?
Yeah it ohmed good. I tried to measure voltage could not get anything. Pcm on the way
I am sure you already checked this.The cable driven throttlebody has a set screw to adjust idle.
What PCM do you have?I'm sure you know but some PCM don't have the IAC drivers...
http://ls1tech.com/forums/conversion...v-hwd-nos.html
Sorry for my bad English I'm french!
Got a new pcm installed and the IAC works it idles great in park. Got a slight surge in gear.
