Page 4 of 4 FirstFirst ... 2 3 4
Results 31 to 40 of 40
Thread: performance truck eddition of truckin mag
  1. #31
    Congrats Dave! Your truck is freakin ridiculous... Any word on RWHP numbers?
    nope not yet tyler... we had it at magnuson on their dyno and on the first pass at 2/3 throttle it ramped so hard and fast it broke a dyno strap (metal part) at 2800 rpm @650 ft lbs, without any timing advance or any real tweaking to the tune...
    I need to get it on a better dyno and get the tune dialed... kenny dutweiler built a similar LSX motor with the same SC and at 14psi he made 960hp to the crank... I am running more boost and more fuel (meth) so I am hoping for 1k at the crank... through my 80e and drivetrain I think 750rwhp is obtainable, maybe more?
    Im still breaking in the engine, its got maybe 400 miles on the block? the tune on it now is very tame, and very rich - i hope to get 600 miles on it before the final tune is complete. I will post final numbers and a dyno graph when i get it done.
  2. #32
    Quote Originally Posted by usabodyguard View Post
    Holy Mother of God... Effing broke a strap??? I can do that too...when trying to rip out a stump with my 3500 Cummins work truck...
    Wow man--I hope you do end up hitting that magical 1k mark. With it being SC, how do you anticipate the RWTQ numbers to be??? What rearend did you end up going with?
    Good call--it is a fine idea to get 1,000 to 1,500 miles of break in done before really opening it up. I know it will be hard, but keep your tiny little girl foot off the GO pedal a little while longer...
    In any case--congrats on the final product! Looks awesome and I am sure it will run even better.
  3. #33
    Wichita KS
    Congrats to you guys that got in the magazine, your trucks are sick!!
    By the way, did anybody read the Readers rap on page 17? About switching to and ls6 intake costing 700-1000 dollars and most guys that do have their wires held together with duct tape?
    2006 Trailblazer SS RWD
  4. #34
    southside VA
    got my copy in the mail the other day
  5. #35
    Jan 2005
    Humble/Houston TX
    Quote Originally Posted by MYSHTBX View Post
    it is that expensive, but ive never seen wires held with duct tape. our harness isnt made for that intake though so you have to get creative to make it look good.
    old mod list: H/C/I/N/E/G 408
  6. #36
    Wichita KS
    The way he makes it sound though is the guys that are doing the swap are dropping a grand for an intake swap and half ass'n the job.... and granted, I haven't done the swap so I could be 180 off but I would think that you could do that swap for a bit less if you lurked the forums and searched around.
  7. #37
    Jan 2005
    Humble/Houston TX
    this is the cost of doing it the right way and average prices i would expect to see.
    intake 300ish
    svo injectors 130ish
    return style ls1 fuel rail 80ish
    new manifold gaskets 20ish
    new manifold bolts 20ish
    new injector pigtails 20ish
    new water pump 180ish?
    new belt 25ish
    relocating idler 10ish
    new map sensor 30ish
    misc fuel lines/adaptors 15ish
    830ish before you start selling off crap you dont need anymore.
    and from MY experience: gains=ZERO
  8. #38
    Quote Originally Posted by TXsilverado View Post
    intake 300ish
    new belt 25ish
    thanks as i fee alot better hahahaha going with the LSXr intake
    Simple: 408 on steroids!
    single digits coming soon!
  9. #39
    Jan 2005
    Humble/Houston TX
    well lsxr wasnt always around haha. you have more than that into the intake anyways
    i still cant see 102mm being necessary
  10. #40
    true, it wasnt available at the time, but i had no choice but to waite since i run bigger heads (ls3/l92) and there was no aftermarket intake available for my setup
    intake, fuel rails, injectors,throttlebody, necassary AN fittings breaded hose, less 2k doesnt matter if its necassary or not, if i gain even 10 or 35 i am happy..
    i like to keep my setup matched so if i have a intake that calls for a 102mm tb then thats what i will put on it, they say the 90mm would fit, BUT mine didnt, thus why mininumize the size (92tb if it even fits ) and go with what its called for? ( 102mm tb ) plus mind you what i do is for my future build of a 408 stroker.
