Converter On the Fritz??
So here's the deal. When I'm just cruising, it shifts fine, acts normal and sounds normal, but when I start to get into boost and get to about 4-6psi, it's like the trans goes to neutral. Boost keeps building but I don't accelerate. Plus, I can feel like a grinding in the trans. If I back off the gas and just accelerate normally, it works just fine. Any ideas??
- You may not post replies
- You may not edit your posts
