You can always add a low fluid level sensor to the tank. Our 90 BMW 325i has a sensor through a hole in the side of the fluid tank and it comes on when low, not empty. That type of sensor will be handy to keep you from ever running out of methanol.
Thanks guys. Meth sounds like a mod I'd like. I'm such an ole woman about making sure things are maintained that I'm sure I'd never run low. Hell I'd be checkin it twice a day knowing me.![]()
2002 white Silverado ext cab. Taillights filled, roll pan w/93 Cad lights horizontally placed, tailgate handle inside, Gaylord tonneau, bed slide & bed rug, all trim removed, Escalade door handles, 18" Enkei & Falcons, Speed grill. Grill shell, bumper pad, & valance painted white. Mirrors painted white. Many interior pcs painted black (over beige), black leather seat inserts and sun visors. 2" dropped DJM lower control arm, shackles/hangers for 4" rear drop. Engine: 5.3 , Radix w 2.8" pulley, 90 mm throttle body, Dart 225 heads, Comp Cam 581-588 224-230 on 114. ARP head bolts. KTech rod bolts. Alky Control methanol injection, Pacesetter lt's into elec cutouts then 4" polished Magnaflow SS mufflers then 4" ovalized SS pipes exiting in front of rear wheels both sides, gas tank removed and 24 gal. fuel cell where spare tire was w/Aeromotive pump, pre and post filters and pump controller & -10 SS fuel line. 160 thermostat MSD wires & Perma Cool fan, 34" radiator, Meziere elec water pump. Valve covers, alternator & brackets powdercoated white. Built 4l60e, 4.56 with Detroit Locker Trutrack. 2 Interceptor logging guages, FAST dual 02 sensor wb gauge, Cyberdyne vac/boost gauge. Truck is actually the property of a little Benji type dog. Pics of him and the truck too www.swardphotos.shutterfly.com
You old hen![]()
Can I have you scheduled to come check mine for me? I WONT let it happen again!![]()
2013 2wd Z71 6.2 crew cab
Old Truck: '04 Chevy crew cab stroked/bored 6.0 to 408ci. forged internals, patriot 68cc stage 3 heads (11.1:1cr), comp 244/246 .600 115lsa cam, 3000 yank tc, built 4L60E, walbro 255, 60# mototron injectors, pacesetter lt's 4" single no-cat exhaust
best time 12.93 1/4 mi @ 103 in the turbo truck.
1968 Camaro Convertible, super sweet!
Adding the sensor in would be the best option IMO like red said.
not letting your nephew drive your truck would be better! but at least yor getting a sweet motor to play with![]()
WORD!Originally posted by Tim Z@Dec 29 2005, 04:25 PM
i third that one!!. but u got the paper so..its all good then.Originally posted by JimS+Dec 29 2005, 10:06 PM--><div class='quotetop'>QUOTE(JimS @ Dec 29 2005, 10:06 PM)</div><!--QuoteBegin-Tim ZWORD!@Dec 29 2005, 04:25 PM
http://www.compcams.com/Community/Articles...p?ID=2041817420
Here's a link to an article for a buildup of a 408 with awesome power numbers.
You decide on an engine yet?
