Results 21 to 30 of 31
Thread: 03 silverado 4.3 to 5.3
  1. #21
    Dec 2010
    Quote Originally Posted by Ray@NP View Post
    In my option DBW is the way to go. On my 06 I converted from 4.3 cable to 6.2L DBW and also converted from class II to CAN. If you decide to go DBW give us a call and we wE can assist you
    thanks for everybodys help and one more thing my truck is a wt does that matter at all?Ill just up date this thread when i start doing the swap
  2. #22
    My truck is a W/T, most my parts came from a fully loaded Z71
    Jan 2012
    DFW, TEXAS
    I'll trade you, I want a black truck instead! and i will throw in a full tank of 87 octane! just to sweeten' the deal
  4. #24
    Dec 2010
    Thanks fenchy i was hopin i was gona need a diff harness or some crap bc mines a work truck
  5. #25
    Dec 2010
    Hey guys need ur help om one more thing,which 6.0 to get?I found a 05 complete with 70,000 miles for 900 bucks with harness.Thanks
  6. #26
    Sounds like a good deal to me
  7. #27
    Dec 2010
    will that year be ok in my 03 as long as i get the harness?And should i be alright with my fuel lines if i cut and use the fittings that are in the sticky on here
  8. #28
    You can use any 01+ engine. The only difference in the actual engine between pre-03 and post-03 is the throttle body. And returnless or return fuel rails. Easy to swap either around.
    Dec 2010
    Thanks Frenchy,how do i know if i have a return fuel set up?I have to lines that run into my spider injection but i seen on here it might be returnless.
  10. #30
    Your trucks an 03? It's a return setup
