You are so misinformed.
I went from a 4.8 to a 5.7 and my mpg (under normal driving) actually improved. Stock 4l60E with 127k has held up just fine, so far I've had the combo for 10k miles and beat on it daily.
The Fleet...
2003 Suburban- 5.4 L59 331CI 10:5.1 Compression -Built by ME
2004 Avalanche- 5.7 LS1 -NOT built by me
2005 Silverado RCSB- 5.7 LS6 -Built by ME
The 6.0 had the longer crankshaft in 99 and 00 so that it would fit on the shorter snout of the 80e converter. In 01 they did away with that crankshaft and just used a spacer to make up that difference.
The 5.3 and 6.0 crankshafts have the same dimensions, so it makes sense that they did away with it in 01 and used the spacer.
I also see that they did away with the EGR in later year engines, if i get an engine without the EGR, what do i do about my truck and PCM that is used to having one (truck is a 1999)?
