Results 21 to 30 of 32
Thread: Is this a 5.3 or 4.8
  1. #21
    Pittsburgh, PA
    10 over your ls1 and use a 4" crank with correct pistons
    4.8/5.3 is same setup. take to 3.9 bore and use 4" crank
    2014 Xsport- 3.5 Eco boost
    412 Motorsports
  2. #22
    Nov 2009
    I can pretty much fab anything so I'm not worried bout Anything, I'm just at a learning curve on the new tech stuff.lol My brain needs an upload with this LS stuff. I also have a 55 Chevy Sedan that has a 454 thats fuel injected, but I always wanted an LS1 in that baby. So I will cut my teeth on the 5.3 and maybe the Sedan will get that LS1 after all. I love the way that engine looks.
    Also does any GM drive by wire pedal work or do I have to look for a certain year? Thats the only think I did not get with the engine
  3. #23
    MidnightRider Guest
    they had DBW before 03
    not on the trucks the pcm changed in 03 and that was the beggining of the ETB trucks
  4. #24
    Nov 2009
    Quote Originally Posted by MidnightRider View Post
    Well the throttle body is drive by wire and the pcm is 12200411 and upon a search they said its 2001-2002. Lets just call it a 2002 engine. It does not matter its going in a 50 plus year old truck.lol
  5. #25
    Pittsburgh, PA
    he asked if they had DBW on the 5.3s before 03 and i replied back with they did in fact with the tahoes and burbans.
    in the 411 pcms there is still provisions in the tune for ETC
    412 Motorsports
  6. #26
    Broken Bow, OK
    Wrong...
    Quik is right about this. DBW was on the Tahoes and Burbs with traction control. My 2001 C3 has it too, but it is a 6.0L.
    To the OP, if you want to go with a cable throttle body, I am looking for one of the 00-02 DBW throttle bodies.
    To stay with the DBW, you will need to have the TAC module from a pre-03 truck too. The 03-up one will not interchange.
  7. #27
    Nov 2009
    Quote Originally Posted by PitchBlackC3 View Post
    Yeah I have it I just need the pedal. I'm going to start looking for one.
  8. #28
    01 with the 385HP Z06 corvette
  9. #29
    Pittsburgh, PA
    Quote Originally Posted by clementeunknown View Post
    LS vettes are DBW
    412 Motorsports
  10. #30
    Nov 2009
    Well got the engine mocked up
