10 over your ls1 and use a 4" crank with correct pistons
4.8/5.3 is same setup. take to 3.9 bore and use 4" crank
2014 Xsport- 3.5 Eco boost
412 Motorsports
 Junior Member
						Junior Member
						I can pretty much fab anything so I'm not worried bout Anything, I'm just at a learning curve on the new tech stuff.lol My brain needs an upload with this LS stuff. I also have a 55 Chevy Sedan that has a 454 thats fuel injected, but I always wanted an LS1 in that baby. So I will cut my teeth on the 5.3 and maybe the Sedan will get that LS1 after all. I love the way that engine looks.
Also does any GM drive by wire pedal work or do I have to look for a certain year? Thats the only think I did not get with the engine
 Junior Member
						Junior Member
412 Motorsports
Wrong...
Quik is right about this. DBW was on the Tahoes and Burbs with traction control. My 2001 C3 has it too, but it is a 6.0L.
To the OP, if you want to go with a cable throttle body, I am looking for one of the 00-02 DBW throttle bodies.
To stay with the DBW, you will need to have the TAC module from a pre-03 truck too. The 03-up one will not interchange.
 Junior Member
						Junior Member
						 Senior Member
						Senior Member
412 Motorsports
 Junior Member
						Junior Member
						Well got the engine mocked up
