put theis PN in 027-13105
06' Silverado RCSB 5.3L 4wd..
HID's Hi, Lows & Fogs
yeah it will work, just use a Y fitting after the FPR...mine was also a 2 stage setup and i just set mine up with a 60psi setting
TOLD YA SO!![]()
01 Silverado
THANK YOU!! I will go ahead and cancel the 5 gal fuel cell, and get the 1 gal one.. find a place to set it in the engine bay and buy the fuel pressure regulator to set it at 60psi..
i was looking to do a setup just like that. it seems pretty straight forward. good luck with everything!
01 Silverado
My mechanic told me I don't need a FPR, that he can control the fuel pressure with a NOS nozzle in the fuel line.. Is that possible??
i cant answer that one honestly...i know my way works and i have proven it...if he says he can do it and you trust him then go with it....it will save you some money. Unless i hear exactly how he would control the pressure then i cant say...now he could possibly use a fuel filter off say a returnless style fuel system and that possibly work
