Results 21 to 30 of 35
Thread: My "HOE" is on the road!!
    if you mill the head it will fix the compression problem, this still make no sence to me.
    thunder racing sells heads that are cnc'd by several different people..
    s10 with 4l60e and cammed 5.3 on the road!THREAD
    "People sleep peaceably in their beds at night only because rough men stand ready to do violence on their behalf.".
    Baton Rouge, Louisiana
    Quote Originally Posted by Lsx10 View Post
    * a guy named Allen.. Good friends with him.. He did the CNC on the heads I bought from Chevrolet. He works at thunder racing. They do all the "in house" stuff now.
    No I didn't get the heads milled..
    I don't understand what you don't get honestly..
    Either W4M didn't compensate for the tune with the heads I used. Or I was supposed to upgrade fuel injectors to compensate for the heads..
    Man I give up on the head situation. Obvious enough the heads was the issue and now I have a running vehicle and everybody here is happy
    right?
    Justin Thomas
    '01 Ta(hoe)
    Just went back all stock for now
    [Today 08:42 PM] murdered_outgmc: Gotta run to get the wifey some coffe and see if there is any rice on the road that needs to die
    the head situation is really rather simple, you had a cammed 5.3 with a 8.8 to 1 compression ratio. dynamic compression ration would be even worse...
    you would want to have about 2.2 points more on your compression. even if the wiring and everything else was done right you would have lost far mor power then you would have gained.
    I'm not trying to be a dick, but no you did not research this if you tried to put this setup togather. buy a book on building performance engines, it will help you alot.
    also shame on your "friend" for trying to give you that setup.
    this would be your engine specs if you wanted to put it into a calculator
    bore 96.01mm
    stroke 92mm
    gasket .053 inches
    cc volume 66.67cc's
    and here is a calculator to plug it into
    Engine Size and Compression Calculator
    stock 5.3 heads are 61.1x cc volume
    ls1 heads are 66.67 cc volume
    keep in mind that is if they are untouched combustion chambers, and alot of port jobs will shape the combustion chamber for better flow which enlarge it even more which would lower your compression even more.
    My point too. It should have run at 6.0:1 compression. Something else was the problem...something was disconnected that got corrected during the swap back to the other heads, the seats or spring set up was off holding the valves open and killing dynamic compression....something OTHER than the cc of the chambers obviously.
    Thats what I was thinking.
    Round Rock, TX
    peanut gallery agrees...
    Well some of the old flat heads...not just F**ds have more like 6:1 as previously mentioned
    Dum Dum Dummmm, the plot thickens.
    -Whatever you say
    Justin Thomas
    '01 Ta(hoe)
