Sounds like a good excuse to change to a quality LSD. You've beat the snot out of that one long enough and its time to put it out to pasture. If your truck was 2wd you would have shattered it long ago with the power you're making. Make sure there are no chunks in the pumpkin if you're going to drive it until Cody comes up.
I don't have G80 either....LOL
There is no sealer or sealant needed for any of them and no additive for any of them either. That's an old school need.
Buy the proper $30 per liter GM stuff.![]()
Put rtv on the cover ,use the black.or RIGHT STUFFIN THE CAULK TUBE.
No sealer. Clean off the old gasket and use a new one. Some of the larger older axles have sealer and no gasket. A 10-bolt has a gasket and sealer makes a mess.
Silicone is incompatible with synthetic oils. It won't be long before it starts leaking if you use it. Get the paper gasket.
i never even use a gasket and doesnt ever leak ,no offense red.right stuff works for me .i was def talking if no gasket,gg.if you have a good or new gasket you probly dont need sealer,but i use it even if i have a gasket.either way ittl be fine.
