Results 21 to 30 of 33
Thread: Help me choose front wheels
    San Antonio, TX
    I love those but 3.5" backspace makes the wheel hang out a mile. That may be okay on a 6" wide rim, mine were 8s and looked like a 4x4.
    Apr 2005
    I have to vote NO on the Kuhmos.
    325/50/15 ET Street on the rear. Oh wait, that is mine!
    Gone, but not forgotten!
    San Antonio, TX
    Ok, I decided on these, but the note at the bottom says:
    "Will not fit applications with 14mm studs."
    I belive my '94 5x5 1/2 ton, 5 lug truck has 14mm x 1.5
    Weld Racing 90-56416 - Weld Racing Draglite Wheels - summitracing.com
    HELP!
    thanks,
    allen
    afaik weld doesnt make truck wheels anymore. Call them and tell them you have a full set but the fronts got damaged and you need replacements. They may make you a set. Yes, trucks have 14mm studs. You could have them drilled out to fit, too.
    San Antonio, TX
    That's bs, oh well, I'm not gonna call and wait for them to make some, I'll just find another set.
    Why does it say, won't fit 14mm studs?
    Apr 2005
    The Centerlines use shoulder style lugs that center the wheel on the rim. Getting the 14mm shoulder style lug nuts is fun sometimes. The 14mm lugs have a large diam and won't fit in the hole. You can easily drill them out.
    Those are effing sick dude! If I had a need for wheels that wide, and I had 5 lug I would get those!
    They only make the 5x5 pattern in 14 or 15" wide.
