Page 3 of 3 FirstFirst 1 2 3
Results 21 to 24 of 24
Thread: Dyno @ Nelson!! 422hp/411tq @ 9 psi
  1. #21
    May 2005
    i gotta get mine dynod...maybe its time to make an appointment and do the SD tune then a dyno session
    ●01 silverado x-cab w/5.3 ● STS GT-67 ball bearing turbo kit(relocated under cab)● Comp 918's ● Comp Hardened Pushrods ● Comp Cam 212/216 .557/.561 114 lsa● 42lb injectors●Walbro 255lph inline●OBX Intercooler● YANK 2600● Nelson SD Tune● Magnecore 8.5mm wires● STS meth Injection●Comp valvesprings● 05' e-fans w/ 34" radiator● ARP rod bolts and headbolts● NGK TR6 plugs● Eaton Posi● DB Rods bagged 4 link● FLT lvl5 4l65e● Apexi AVC-R boost controller ● z06 6 piston brakes front/4 piston rear 14" rotors ● Goodrich SS brake lines● powdercoated frame
  2. #22
    Spring, Texas
    Ya, we've got close to the same mods. How much boost are you running? With the bb turbo and it being a 67, at the same psi you should be making more hp than me. Hurry up and do it already!!
  3. #23
    Jan 2006
    Quote Originally Posted by speedaddict View Post
    Yea get that thing dynoed, I want to see how that cam runs!
    Jamest
    12 Sec. Club! SOLD
    SOLD***
  4. #24
    May 2005
    Ask Allen...I baby my truck. I think he was getting frustrated when we were tuning it cause I'd let off on the gas...haha When I'm on it, I run 9-10 psi..I hope to get #'s where youre at. I'm shooting for 450whp
