Good note Greg. Make sure to get a Comp custom grind from TSP.
What happend if i dont put the 3000 stall on it? I mean, I will, but what if i dont?
whats the "wow" stands for bud? lol
06' Silverado RCSB 5.3L 4wd..
HID's Hi, Lows & Fogs
By using a stock stall with that cam, you will loose lower end power. It will just be a dog down low.
I only said "Wow" because I didn't think you would go with the custom grind cam. But good choice though...
TSP (texas speed and performance) you might as well get the 7.4 hardened pushrods from them while your at, it should be about 100 bucks, and youre gonna need springs i used 918 comps, but apparently i got a good batch cuz some guys have been breaking them, anyways talk to these guys about where to find a good set of springs, also if you dont use TSP for your cam, Nelson gets thiers ground through COMP im pretty sure, so if you wanna compare prices.
I will have to send TSP an email cause I cant set those specs for a cam.. I will send them an email.. thanks guys! Any idea on a good set of springs??
what if I get a 100 shot of spray??? would those springs work??
02' silverado ext. cb 2wd , 5.3 liter 325c.i. LM7, ported and polished throttlebody with bypass, Jannetty Racing 87 octane dyno tune, cold air intake with custom ram air, Heavy duty built 4l60e with vette servo, Z-pac clutches, "The Beast" Sunshell, transgo shift kit, yukon 4.10 gears with true trac, custom exhaust with Moroso Spiralflow, no cats, MSD 8.5 race wires, NGK TR55's
