Page 3 of 3 FirstFirst 1 2 3
Results 21 to 23 of 23
Thread: 4L80E diagnostic
  1. #21
    Jul 2005
    Azle , Texas
    I did the .096 "firm" size holes on my 80e , was way to much for the street , chirped second every time it shifted , but Greg you may like it that hard .
    I shot penned the holes back to the "average" hole size (.076) , and if I want more kick I do it through the tune .
    But the Instruction say if you are using a "off-road use and with small diameter high stall converter make holes .120" .
    And you about right 4 hours in truck application .
    Now what is a tune again?
    Comp Cam 54-412-11 , Int:265, 212, .522 , Exh: 271, 218, .529 , LSA 114 , Longtube , CAI (Vararam) , TransGo HD2 shift kit , tuned by me with EFILive
  2. #22
    I didn't realize your truck had the 80e trans, Gibb. How's it holding up? I was surprised this 2002 trans I bought had been rebuilt.
  3. #23
    Jul 2005
    Azle , Texas
    No problems , love the TransGo HD2 kit , did not go as far as you did with the install (in truck) , yours should be awesome with the whole kit installed .
    Rebuilt 2002 is strange , but I guess not all are tough as we think .
    Forgot to add , when you or Nelson does the trans segment swap (what EFILive calls it) into your current tune , set everything back to stock , except TM , and shift times , you don't need increased line pressure after a kit install , but I bet you knew that already !
