Before i took the crank pulley off, should i have put two dots, to make sure it went back on, on the same spot on the crank, or is it all already balanced?
2004 4.8l 6 speed manual 2wd
Looks: 22" foose rims with Fierce tires, SS front bumper, SS Front Grill, 2/3 lowering kit.
Performance: Volant Intake, 3" exaust with Spintech muffler, Pacesetter LT's with Y pipe, TR cam 220/220 .551 112 lsa, T56 Tranny with the Keisler short Shift kit and LS7 Clutch, Quicktime Scatter Shield, ASP Underdrive pulley kit, Dyno tune by Rick at Synergy Motorsports
Soon to Come:Eaton locker, Electric Fans..Does it ever End?
Just put it back on and tighten the crap out of it. Follow the torque instructions.
Bolt a metal plate to it.
Just to prove Redheartbeat right I set up a dial indicator and found out that 240 degrees tighten the adjustment nut it comes out to .045".
What is the ideal amount of preload on stock lifters?
CompCam RR destructions say 180 degrees which would give a preload of .033". Any thoughts?
2002 GMC 1/2 ton Sierra,4WD, Xct cab, camed, mid-length headers, Nelson tune, electric rad. fan, trany cooler, Heavy 5750 lbs with topper.
So, me and my brother got my truck all back together, minust the push rods and valve covers. When they get here on tuesday i'll get a video of what the truck sounds like open headers. it ought to be nice![]()
do you have a stock tune now?....after installing my cam the truck would barely run untill i got a tune
05 RC, LME 6.0, 243 Heads, LSA Rods, 11:25 Forged Pistons, Cam Motion Custom Grind, 4:10, Eaton LSD, Narrowed Rear-end w/ Chromoly Axles, Pacesetters LT's, SLP Loudmouth II Mufflers, Volant CAI, Yank SSTB3600, Bosch 42 lbs inj's, G-Force Tune, FLT Level 4 Trany, Belltech 2/4, Times: ?
I was about to say--why remove the intake??? But oh well, everybody lives and learns... Good work dude! I bet you are pretty happy you got everything in without problems! Yeah, it will take 3-4 times for it to start...but once it does, you'll LOVE the idle on that biatch!
Actually it started up after the first crank (i did prime it a little though, turned the crank a couple of times, to make sure oil was movin)All i can say is it souds bad ass straight headers. It does die a if i don't keep my foot in it a little bit. Its a manual though, so i can keep it the r's up till i get a tune. I plan on getting it tuned friday. And i plan on getting the exaust put on tomorrow. headers, then cats, then y pipe, i think, down to a spintech muffler, out to my turn downs. i'll get the video up of what it sounds like straight headers sometime this week. I'll also try to get a video up of what it sounds like after i put the exaust back on too.
Man thats sweet, Congrats on the swap. let's see that Vid.
00' 4.8l 5spd, K&N intake, Granatelli M/A, Shorty headers, Hypertech prg., 160* 2/4 drop
