Page 2 of 2 FirstFirst 1 2
Results 11 to 16 of 16
Thread: What to check on used motor
  1. #11
    Oct 2006
    <div class='quotetop'>QUOTE(GMCwantsLS1 &#064; Jan 25 2007, 08&#58;26 PM) [snapback]81242[/snapback]</div>
    I&#39;m sure the Escalade has the 5.3L too.
    What??? I only want it if its a 6.0L. Should I seperate the two to check the block ID????
    I am going to look it over good...but I wont be able to tell the two apart w/o look at the back of the block or is there an easier way??? IF it does have the 317/alum heads then I should be cool??
  2. #12
    Yeah, 317s are only used from the factory on 6L engines. They could have been swapped on there but it would reduce compression and performance, so not a likely swap onto a 5.3L engine.
  3. #13
    Nov 2006
    Ok, found the Transdapt number I used. It was the 4592 kit. It came with motor mounts that were useless.
    So just get the plates if you go with Transdapt.
  4. #14
    Oct 2006
    well I am happy to announce it was a LQ9&#33; Caddy HO 6.0.
    Alum heads
    He had the trans apart and I saw the block marking.
    wiring is choppy but I have the PCM, MAF (or what ever that thing is by the airbox)
    I will take some pics as I get it out of the truck, its cold here in Michigan.
  5. #15
    Nov 2006
    Plano, TX
    Congrats man - you&#39;ll love it. I love mine Are you going to install as-is or will you be upsizing the bumpstick or ??? For sure while you&#39;ve got it out consider installing a converter&#33;
    Mr. P.
  6. #16
    Oct 2006
    here is my other 6.0L
