Engine and tranny are in, its out of a 95 camaro, with a 6 speed. Using the 5 speed that came with the truck which is a 4x4. Most of the stuff looks straightforward but im a little worried about the VSS. What does the VSS connector look like on the camaro harness? Do i just connect it to the tranny? Is my speed sensor the 40 pulse one that i need? Not using the ac, getting the pcm reprogrammed to kill the vats. What are the snags im going to run into? Can i just wire my stock gauges to the temperature sensor wire, and oil pressure wire in the harness, or just go direct from the gauge to the sensor, are they compatible? I am using the 5 speed (nv3500 i think) that came stock in the truck, with a centerforce, is it possible to make a t56 work with the transfer case?(a bit of an after thought) Thanks in advance!
- You may not post replies
- You may not edit your posts
