Results 11 to 20 of 25
Thread: Turbo Grind cam has got to go!!!
Threaded View
    Comp Cams Extreme Energy FI Cam $250+shipping
    Used Comp Cam for turbo applications. 8000 miles. This is an Extreme Energy model with the very aggressive ramp angles and is designed for forced induction only. You will lose HP if you attempt to use this cam in a naturally aspirated engine unless you're running nitrous on an almost race-type engine. Specs are...
    SERIAL # D 8917-05 SPEC CARD # 07125505
    PART # 54-000-11 CAMSHAFT, LS1 CHEVY LS1/GEN III '97-UP
    CORE C54-11I CAMSHAFT BLANK, LS1 1997 UP 5.7 CORVETTE Special
    Grind
    GRIND # LS1 3730 /3724 HR113+2
    DURATION @ .050 INTAKE 240
    DURATION @ .050 EXHAUST 228
    LOBE LIFT INTAKE .3580
    LOBE LIFT EXHAUST .3460
    VALVE LIFT INTAKE .608
    VALVE LIFT EXHAUST .588
    LOBE SEPARATION 113.0
    DURATION .006
    INTAKE C/L 111.0
    TAPPET LIFT INTAKE 289 degrees
    TAPPET LIFT EXHAUST 277 degrees
    CAM ADVANCE 2
    VALVE TIMING .050
    VALVE OPEN INTAKE 9
    VALVE CLOSED INTAKE 51
    VALVE OPEN EXHAUST 49
    VALVE CLOSED EXHAUST 1-
    JOURNAL DIAMETER STD 2.165
    INTAKE LOBE ID 3730
    EXHAUST LOBE ID 3724
    DATE SETUP 01/25/2005
    $250 plus shipping. Local pickup available in the DFW TX area.
