Page 2 of 2 FirstFirst 1 2
Results 11 to 18 of 18
Thread: FREE PARTS...
  1. #11
    Nov 2005
    ohio
    WELL, the truck is still down, looks like the G-80 took out my Pinion gear! Had to run to Summit to get a gear set, and have been running around looking for new bearings. The chevy garage wanys 100$ for a set of diff. bearings!! Thank god i found them at NAPA for 50$ no one else had them. should have the detroit and gears set up by lunch time tomorrow. What a f--king expensive job this damn G-80 cost me!!
  2. #12
    It's not like you've ever heard what a piece of crap the G80 is.
  3. #13
    <div class='quotetop'>QUOTE(Tim Z &#064; Jul 21 2006, 06&#58;34 PM) [snapback]58646[/snapback]</div>
    WELL, the truck is still down, looks like the G-80 took out my Pinion gear&#33; Had to run to Summit to get a gear set, and have been running around looking for new bearings. The chevy garage wanys 100&#036; for a set of diff. bearings&#33;&#33; Thank god i found them at NAPA for 50&#036; no one else had them. should have the detroit and gears set up by lunch time tomorrow. What a f--king expensive job this damn G-80 cost me&#33;&#33;
    did i not ask if the gears were ok? dam that g-80... no more worries now though...its all ok...
    38" swampers, 350 tbi, 14 bolt rear, 10 bolt front
  4. #14
    Nov 2005
    ohio
    <div class='quotetop'>QUOTE(hummertech &#064; Jul 22 2006, 12&#58;46 AM) [snapback]58663[/snapback]</div>
    the ring gear is fine, you just couldnt tell about the pinion till we pulled the differential out. Then we saw the chunk out of it. Your right, nomore worries till the next breakage&#33;
    <div class='quotetop'>QUOTE(RedHeartbeat &#064; Jul 21 2006, 10&#58;50 PM) [snapback]58653[/snapback]</div>
    It&#39;s not like you&#39;ve ever heard what a piece of crap the G80 is.
    LIVE And LEARN &#33;&#33; I figured with turbo lag it would last a while, I was wrong.
  5. #15
    Aug 2005
    Damn guy. Breaking parts already&#33; I am proud of you. What will be the weak link after the rear end?
    I am saving my pennies now for a rear end and a driveshaft.
    03 Chevy ECSB, Z71, 6.0L(LQ4), Maggie @ 9PSI, 4l80E, PI Vig 2800, Detroit True-Trac, 4.10, 90mm LS2 TB, Meth Injection, HSW Dry N20, LPE GT7 Cam, 918 springs, Dynatech LT's, Hi Flow cats, custom stainless exhaust, DMH cutouts, DJM Suspension Drop, E-Fans, AirAid, HPT 2Bar SD Tuned, 11.68 @ 114.2
  6. #16
    Dec 2005
    I DO MY REAR FIRST AND MY TRANNY GOES, TIM DOES HIS TRANNY AND HIS REAR GOES OUT&#33; IM TELLIN YOU GUYS STS DOESN&#39;T F AROUND&#33;&#33;
    http://i76.photobucket.com/albums/j1...o/789547ee.jpg
    1999 Silverado LS RCSB 5.3 Liter (16.02@83.5 bone stock) (with mods ??.?? @ ?)
    STS Turbo Kit (5 psi), GT67, STS Intercooler, 42lb/hrs, 255 Pump, 212 216 Comp Cam, Nelson STREET Tuned, Eaton LSD, 4.11&#39;s, Phoenix ReTrans Stage 3 4L60E, 160 t-stat, B&M Supercooler.
  7. #17
    <div class='quotetop'>QUOTE(Turborado &#064; Jul 25 2006, 04&#58;31 PM) [snapback]59029[/snapback]</div>
    Damn pervs talking of trannies and rear ends.
  8. #18
    Nov 2005
    ohio
    <div class='quotetop'>QUOTE(RedHeartbeat &#064; Jul 25 2006, 06&#58;33 PM) [snapback]59037[/snapback]</div>
