Page 2 of 2 FirstFirst 1 2
Results 11 to 16 of 16
Thread: ladies and gentleman
    did you get ahold of Austin? BTW, what keeps you from using the stock mounts and you flip a set of adapter mounts around backwards? Us OBS guys have been doing that for a while so that we don't have to change engine mount platforms.
    DBYRD Guest
    <div class='quotetop'>QUOTE(RedHeartbeat &#064; Jun 22 2006, 09&#58;34 PM) [snapback]56067[/snapback]</div>
    did you get ahold of Austin? BTW, what keeps you from using the stock mounts and you flip a set of adapter mounts around backwards? Us OBS guys have been doing that for a while so that we don&#39;t have to change engine mount platforms.
    never called him, but will get ahold of a junk yard soon. how do u flip the mounts backwards???
    normally the adapter plates point to the front of the engine. Just reverse them so that the pointed ends go toward the rear. You&#39;d have to take the left side and put it on the right side and visa-versa.
    DBYRD Guest
    <div class='quotetop'>QUOTE(RedHeartbeat &#064; Jun 22 2006, 10&#58;49 PM) [snapback]56073[/snapback]</div>
    cant do that one side is spaced different than the other. im screwed i&#39;m getting the full setup and cutting the old ones out then welding the new ones in. bout to lay down some serious cash on this shit. engine= &#036;1700. flywheel=&#036;130?, motor mounts=&#036;? plus ac and fuel lines. tired of spending&#33;
    Wow, that&#39;s cheap. Come talk to me when you hit &#036;5,000.
    DBYRD Guest
    <div class='quotetop'>QUOTE(RedHeartbeat &#064; Jun 23 2006, 01&#58;45 AM) [snapback]56085[/snapback]</div>
    wont be long, i plan on having well over that into this truck eventually, she&#39;s going to the grave with me. u haven&#39;t seen the to do list?? lets just say everything will change eventually&#33; from hood to rollpan everything in between will change i promise. inside will be astounding when i&#39;m done i can&#39;t wait. if it&#39;s out there and it looks good, it will be on/in this truck&#33;
