<div class='quotetop'>QUOTE(SCIV @ Feb 25 2006, 10:31 AM) [snapback]45334[/snapback]</div>Great, thanks. I need pictures 'cause I can't read.Nope, nothing exciting though. Here's one anyway.
2000 Sierra 2500 HD. 408 (11-2007) Whipplecharged, Big (18x24x4) FMIC.
Okay, this is starting to suck. Plugs went quick. getting all this piping in is like trying to get 10 lbs of sh!t in a 5 lb bag.
4 1/2 hours just to get the s/c mounted, serp belt ran & intake & filter mounted. Had to take off the bracket that holds the brake lines and "massage" the routing of the lines. I'll post pictures tomorrow.
Back to work.
Gone, but not forgotten!
SC let me know if you need any help Im headed up that way Mon to go to the tractor supply up there to get my toolbox for my truck.
your work is going to be worth it!, i thought the fuel pump replacement was harded than the injectors,maybe cause the assembly is something ive never worked on before. good luck with your project.
