Page 2 of 8 FirstFirst 1 2 3 4 ... LastLast
Results 11 to 20 of 80
Thread: Early Classic motor mounts
    Oct 2005
    Baton Rouge, LA
    What's the space specs on the 60's trucks versus the 80's trucks?
    The mounts I got from BRP (and the way I mounted them) puts my 5.3 about 4" off the firewall in my '86. The reason I'm leaving this way is because I'd like to leave the 5.3 compressor in the stock location. If I switched the mounts to the opposite side & direction, the 5.3 would move back 2". As it stands I'll have 2" clearance (at the most) with e-fans.
    Jan 2006
    Las Vegas, Nevada
    Update: I haven't stopped working on the truck, I just moved on to areas other than the motor swap. Just completed the 2.5"/4" drop and power disc brake installation. More work that I thought, everything was covered with 40 years of grime and numerous bolts would not let go.... broke a few along the way making a parts run unavoidable...
    But man, what a difference in attitude!
    Next up is the fuel tank relocation to get it out of the cab (I'm using the poly Blazer tank), fuel pump and fuel lines.
    I've been playing around with stock intake parts but apparently I won't have room for all the bulky stock stuff and will have to fabricate something.
    Looks like a BeCool/Spal 16" single electric fan will fit my radiator but is kind of pricey for the whole module, which includes brackets, fan, relays and wire harness (~ $300). I guess I could just buy the fan alone and fab up my own brackets.... My radiator core is 22 x 18, anyone have a suggestion?
    1965 C-10 shortbed stepside, 2003 5.3/4L60E conversion. Power steering, tilt wheel, power front disc brakes, 3.73 one wheel peel, 2.5/4 inch drop, relocated fuel tank and battery, 2002 Silverado buckets and console. Swap Pics
    1968 Camaro 95LT1/4L60E lots o' mods Web Page
    1961 Corvette project.......... C-4 suspension and brakes, 02 LS1/T-56 awaiting installation Pics
    San Marcos Texas
    I have the LS1 Camaro fans from a 2002. I fabed up my own brackets and it works great. I'm sure you can find some for around $100.
    Jan 2006
    Las Vegas, Nevada
    <div class='quotetop'>QUOTE(GMCwantsLS1 &#064; Feb 23 2006, 03&#58;46 PM) [snapback]45196[/snapback]</div>
    I have the LS1 Camaro fans from a 2002. I fabed up my own brackets and it works great. I&#39;m sure you can find some for around &#036;100.
    What are the dimensions on these and did you use the whole module? I have done a similar swap on my 68 Camaro and I used LT1 fans but the radiator on the Camaro is much wider and that assemby won&#39;t fit my narrower truck radiator. Are LS1Camaro fans different or did you separate the fans from the mini-shroud and mount them separately?
    San Marcos Texas
    <div class='quotetop'>QUOTE(kwkenuf &#064; Feb 23 2006, 06&#58;15 PM) [snapback]45198[/snapback]</div>
    I used the whole setup. I didn&#39;t realize the radiator is so small in those trucks. LT1 is the same or very similer. I guess you could swap to a cross flow radiator?
    Jan 2006
    Las Vegas, Nevada
    <div class='quotetop'>QUOTE(GMCwantsLS1 &#064; Feb 23 2006, 06&#58;28 PM) [snapback]45208[/snapback]</div>
    Yup, it&#39;s definitely narrow. I have already swapped to a cross flow BeCool aluminum radiator....
    I used the Black Magic fan on my LT1 setup. It&#39;s small enough and pulls about 2800 CFM. It also has a built in thermostat.
    i fabed mine to accept a normal mount.
    http://home.comcast.net/~airdeano/1965/gallery.htm
    i did no frame mods at all to make my 5.3L fit...
    check my pix..
    airdeano
    Jan 2006
    Las Vegas, Nevada
    <div class='quotetop'>QUOTE(airdeano &#064; Feb 23 2006, 09&#58;17 PM) [snapback]45234[/snapback]</div>
    check my pix..
    airdeano
    Thanks for the reply. I checked out your pics extensively and sent you a PM before I started my project. The pics in your gallery do not show the motor mounts and it appears the left framerail has been narrowed considerably from stock. I was curious what mounts you used as I was scrounging parts for my swap. But it&#39;s water under the bridge now. My motor position is set and I&#39;m happy with it. Thanks for posting the pics, it&#39;s good to see more old iron&#33;
    Jan 2006
    Las Vegas, Nevada
    Working on the fuel system now and I was curious. Does anyone know of a GM in tank pump that used the old small lock ring style attachment rather than the large diameter modular pumps that are in the new trucks? Maybe the old Buick Grand Nationals? I&#39;m using a poly Blazer fuel tank and would like to sink a stock style in-tank pump in it if possible. Here&#39;s a pic of what I working with. The stock fuel pickup is lower left, the fitting on the upper right is the sender for a new fuel gauge. I have a external inline hi pressure pump I can use but...... Thanks in advance for any suggestions...
    Maybe this will work better for pics. I&#39;ll keep a bunch of pics on the swap at Photobucket
    65 C-10 motor swap
