Could use some help with how to remove the upper water pipe on a 2004 5.3 (want to modify the pipe)
Thanks
Thanks
Upper water pipe? The steam vent that goes from head to head? If so, two little hex bolts on each head hold the fittings down.
Sorry, should have been clearer...the upper pipe to water pump. Thanks
IS that the one going to your heater core.
No...it goes to the radiator (pipe in picture)
you can use an fbody waterpump with spacers between it and the block to get the alignment back to the pullies.
No leaks on mine, no sealer
