obs to ls conversion going different route
hey guys i am starting out with an 89 z71 stepside sierra that i have done a frame off resto on. i have not figured out if i am going with the 5.3 or the 6.0l it depends on what i can get the better deal on. now some may question my next decision. i am planning to go with a carb set up and run my 700r4 with tranfer case. i figure it is easier to run the carb set up then mess with the computer and wiring harnesses and fueling. i can use all my brand new fuel pump and braided lines with just a fuel pressure regulator with by pass. the reason i plan on using the 700 is 1 because i have it. 2 i dont not have to change any mounting locations and can use my stock drive shafts and 3 because i have a friend who builds trannies and is going to put the 5 planetary gears in it and build my 700 up to handle the power and it also does not need any electronics to run it. my main questions are with mounting the motor to the transmission. i know that the tranny will bolt up to the motor minus 1 bolt. i know you need a spacer for the flexplate. where i get lost is can i use the stock ls flex plate with my convertor and drill new holes? do i need a whole new flex plate? do i need to run spacers inbetween the flex plate and my converter also does the spacer go inbetween the crank and flex plate moving the flex plate farther from the engine causing the starter to not be lined up? or does it goe between the flex plate and transmission?
- You may not post replies
- You may not edit your posts
