Page 2 of 7 FirstFirst 1 2 3 4 ... LastLast
Results 11 to 20 of 64
Thread: Using 2wd and slicks in a 4x4?
  1. #11
    Mar 2010
    Midland, TX
    If the truck is in 2wd it doesn't make a crap what size tires are on the front. Autotrack doesn't automatically engage your transfercase if you're slipping when in 2WD - it ONLY engages when you select the mode "AUTO 4WD".... its a screwy setup but works good at slow speeds on slick roads, other than that... worthless. Pretty much a soccer mom 4wd option to make them feel better when driving in crappy weather.
    - 5.3 Stock Internals - Cal Speed Stainless LT's - 18" Magnaflow - K&N Drop In - Airaid Intake Tube - Nelson Tune -
    Shopping List
    - Cam - 3200 Circle D Stall - 10" King Coilover Shocks - 16" King Reservoir Shocks - FG front Fenders - 17" Methods -
  2. #12
    I've heard otherwise. That's all I'm saying. With the Stabilitrac and Autotrac combination, I've heard there are issues. But I'm open to all opinions.
  3. #13
    Mar 2010
    Midland, TX
    A thermal coupler engages the front differential - when autotrack is turned on the transfer case is locked in 4X4 with the front diff engaging when slippage is detected ONLY when the AUTO 4x4 button is turned on.... have you ever tried a burnout in 2wd?
    Shopping List
  4. #14
    Think about this Justin...if 2hi still automatically engaged the t-case then you wouldn't be able to do a burnout. Just saying.
  5. #15
    come on dude, use some damn common sense like if you put it in reverse the engine rotates the opposite direction internally
  6. #16
    Mar 2010
    Midland, TX
    I'll have to remember that one... They just need locking hubs and an atlas.... the 4wd setup on these have a lot of room for improvement...
    Shopping List
  7. #17
    Broken Bow, OK
    Yes, but the later model trucks have ABS sensors front and rear. Not sure how it would affect the stability, ABS and traction control systems. Haven't messed with the new body trucks much.
  8. #18
    I'm not talking about mechanical issues guys. Speed sensors not jiving and such.
  9. #19
    Quote Originally Posted by PitchBlackC3 View Post
    Exactly what I was getting at. I guess I should have gone into further detail. If I was to pull the fuse relating to all that stuff, it may work without going into a limp mode of sorts.
  10. #20
    put that sucker in 4hi and go!
