sooo tonight i had a issue with my truck....the lq9 swap went fine and the Nelson Tune went great, just finished breaking it in and doing the first oil change......well i finally got a chance to jump on it for a 123 gear shift on the highway tonight.......and the motor blew oil out from under neath the engine and was burning on the exhaust pipe......but then i had a terrible miss on cylinder 1-3, and a fouled plug on cylinder #3 but it was still firing and the injectors are new 42# Delphi units.......i dont think it blew a head gasket bc of no coolant loss or smell, just a lot of raw fuel, and the porcelain broke off the #3 plug inside the head ( the part that covers then firing element and electrode)........replaced both 1-3 plugs and wires......still have a miss, and i think i have a bad PCV selector valve from STS thats the only place that the oil is found on the top of the motor right near the valve and on it....and now where else.......but it is alllll over the bottom of the truck. and help would be great. Tomorrow i do a comp. test and a bore-scope down the holes.
..........SOLD :-(
