Page 2 of 2 FirstFirst 1 2
Results 11 to 19 of 19
Thread: LS1 into 95 Gmc Seirra
    Rockwall, TX
    might as well get long tubes if ur doing a sts..... schoenfeld makes a set for $250 for a ls1 in obs silverado
    1989 RCSS 5.3/4L60E swap
    - 224/230 .581.591 112lsa,
    - 3200 Stall
    - DJM 4/6 drop
    - Nelson Tuned
    Building the truck GM never did..
    Quote Originally Posted by T-Stark View Post
    Longtubes with a turbo are a bad idea. They dissipate heat faster than cast manifolds which is bad for boost.
    All good info. Thanks all. But I got to fix the wiring harness under the dash too. It got fried.
    Spring, TX
    Quote Originally Posted by overgrownasian View Post
    the LS1 should just drop in with out the custom mounts right? stock, my truck has the 5.7 350 motor in it, which in turn is actually the same motor series for the LS1 right?
    The LS1 and other LS engines are a completely different design than the GEN I and GEN II SBC motors aka 5.7 350. Parts and mounts are not interchangeable.
    '02 Silvy: Z71 EC Step Side 5.3L Nelson tuned
    2013 GMC Acadia: SLT1 Carbon Black
    1976 Corvette Stingray: Trying to save it, progress is slow.
    ^Ricky's Sweet PS Skilz
    09/21/2010 02:31 <danger_ranger83> I'm not really worried about the looks...I want it to be fast and ugly...bc no one wants to get outrun by something ugly
    Ahhh. Thanks. Learn something new everyday.
    STS systems don't rely so much on heat in the exhaust system. He can always wrap the pipes to hold heat in or have the headers coated inside and out.
    This is true as well. I guess the fact that they are mounted so far back would make the heat issue irrelevant.
    Los Angeles, CA
    I read somewhere that there ar two types of motor mounts. One that keeps the engine at its current location but moves the transmission 1" foward and would require minor modification or the second option is that the engine would be moved back 1" back keeping the transmission in its current location. I personally like the second option since it would keep the weight more centered and should make the truck handle better.
    Nov 2010
    Durant, Ok
    Dirty dingo mounts are the best imo. They are adjustable and will go right into stock location
    Josh ----- 95 Z71 ecss -6.0 swap finished 10k miles ago, nelson tuned, built tranny, 2800 converter, 4.56s truetrac
    2000 z28 a4 longtubes, true duals, ported throttle body, ls6 intake, slp lid (lost in divorce lol)
    79 camaro small block street car 11.60 @ 116 (sold)
