ok, so i thought i'd save myself some money and rebuild a trans on my own. It went smoothly, i am pretty sure i didnt leave anything out. Put the trans in last night and lo and behold, nothing! No forward, no reverse, nada. It doesnt matter if i shift it manually or unplug the connector, i have nothing. My first step was to check the pump. I unplugged a cooler line and fired it up to see trans fluid spray about 8ft out of my truck so i think the pump is fine. The rebuild kit i used came with a vb plate and some new gaskets, thinking maybe that was it i dropped the valve body, made sure all the balls where in the right spot, then replaced the seperator plate with an oem one from the dealer. Still have no movement. Im stuck, literally. Anyone know what it can be?
