Results 11 to 20 of 27
Thread: 408 tear down after high blowby issue
Threaded View
    Well, finally decided to tear the 408 down and see why it had the incredible amount of oil blowby in the crankcase. The prognosis isn't good. Number 7 piston had a lot of deformation to the point that the piston rings looks like a big smile, obviously caused by excessive heat. Pistons 1, 3 and 5 also had deformation in between the top and middle ring causing a loose fitting top ring on one side. I suppose there had been a fueling issue on the LH side of the engine. I think the bores are fine on that side. I need to have number 7 bore checked to see if there is any out of round that might cause future issues on a new set of pistons/rings.
    My next decision is to figure out how to build it up for the turbo. I have the option of -32cc, -28cc, -8cc (what came out of it) and many others. I also have my 64cc P&P Patriot heads and a set of stock 71cc LQ4 317 heads with dual Patriot springs already installed. I'm trying to decide if I should go very low CR using the -32 or -28 cc piston and install the 317s or go for the higher flowing heads and sacrifice a few lbs of boost.
    I have a Bosch fuel pump I'm going to install before the 408 goes back in so the fuel supply will not be an issue. I am also going to bypass the variable speed fuel pump wiring and run a 1/2" fuel line to the intake along with my billet fuel rails from my old truck. I'd love to be able to push a solid 15 psi of boost on pump gas.
    Suggestions? Am I nuts? (most likely)
