Results 11 to 17 of 17
Thread: electric water pump drive
Threaded View
    Ok just throwing this idea out there “electric water pump drive” I see the kits advertised in jegs for around 100 and then I see reg electric water pumps for ls1’s for around 450-500. Has anyone ever fab’d up one to a lsx motor? After looking at the drive belt set up on my 5.3 it looks like alls it would take to run a electric water pump drive kit is a new location for the belt tensioner to keep the belt off the water pump. That would result in a much much shorter belt set up and the removal on the dead pulley on the pass side of the motor allowing you to mount any intake manifold you wanted to mount. Then you would have to remove the water pump pulley (after this it become all speculation and theory) install the new slotted pulley and make a mounting bracket for the E motor.
    After looking around on line for gains with electric water pumps I found this
    http://www.superchevy.com/technical/...mp/index1.html
    In there testing they gained a max of 6hp and a avg of 3 and the same with tq. I’m not sure if this would be more or less with a lsx motor because testing was preformed on a sbc gen 1. Any thoughts about this?
    **here they say 10-12 hp on lsx motor
    http://www.lgmotorsports.com/catalog...oducts_id=1590
