Page 2 of 2 FirstFirst 1 2
Results 11 to 20 of 20
Thread: Gotta love the heat
  1. #11
    Broken Bow, OK
    To the OP, sounds like your clutch fan is going bad. Course your plans to go efans will fix that.
  2. #12
    A 160 tstat is $30 at orileys. I'm definitely saving for the Trick efans.
  3. #13
    i was having the same issues trav
    i put in the 160 tstat.. .got my tune setup for efans.. cuz trucks with clutch fans dont have that setup in the tune, made a harness, got efans on the cheap.. and its been ok.. until i blow a fuse then the temp goes up.. but normally stays at 180, even sitting in traffic.. i figured out my fuse popping issue, so now thats not a problem.
    Sponsored by Taylor Wires!
    Sponsored by PowerMaster!!
    Sponsored by FROZEN BOOST!
    Sponsored by US Speedo!
  4. #14
    GA
    i just scored a set of ls1 fans off ebay for 65 shipped. Maybe that will help with power and cooling in these humid 100 degree GA temps
    04 5.3
    224/224 .566 .566 114
    3200 Circle D
    LT's
    60e
    Nelson Tuned
    p1sc in closet
  5. #15
    Quote Originally Posted by Trevor View Post
    I wish we had 100 degree days...well we do but it doesn't get down to 100 till around 8:30-9:00pm.
    I just got invited to do a taste test for a market research company in 2 weeks paying $130 so I will be clostridium to getting the fans. I'm thinking that I will up to the 14" fan to maybe help fight the stupid temps here.
  6. #16
    Drain coolant... flush thoroughly... Add 2 bottles of water wetter and the rest distilled water, Then add electric fans later
  7. #17
    Jun 2010
    West Texas
    I have 160 t-stat in mine with the dual 15" electric fans and sitting still in traffic with the AC on it never goes above 175, and we have 95-105 days here in the summer. Also I have used the water wetter and it works ok but found out if you dont change out the fluid after 12k miles after adding it, it will break down and clogged up the radiator.
    RUN WAT U BRUNG!!!!
  8. #18
    Quote Originally Posted by PurpleMinivan View Post
    So no dex-cool???
  9. #19
    Quote Originally Posted by RUFFNECK View Post
    105 is nothing here...last week we had temps over 110 every day. I think the highest I saw from the thermometer out by the pool was 120...and it's in the shade.
  10. #20
    phoenix az
    yeah last week i saw 106 in the shop. u might try flush the rad. and condensor out with a garden hose. flush out all the dirt and bugs in the fins
    1998 chevy 1500 with 6.0/4l80e comp cam, tune, exhaust,
