when i broke mine it didnt leak, now its fixed cus i did the heads, but my manifolds only have 4 bolts on each side![]()
anyone know if they are common to break?
ya they break all the time. Sometimes without even touching the bolts. I see them in work all the time, where manifolds will start leaking cuz a bolt snapped.
Are they breaking on modded engines, stock or both? I'm guessing it's just the heat that finally gets em?
2010 Silverado ECSB LS 4x4. Only mods so far are a K&N drop in filter and a Rough Country 2" front level kit
I see the studs broken on 6.0Ls all the time. Seems the back bolt on both sides is the first to go. My truck has the driver's side rear bolt broken off, doesn't leak so I haven't messed with it. I'll fix it when I do LTs.
