Results 11 to 20 of 24
Thread: Sts Turbo Kit With Intercooler
Threaded View
    NOW $2300. Up For Sale Is A Used Remote Mount Sts Brand Turbo Kit. It Has The Optional Ball Bearing Turbo Upgrade. Turbo # Is 6776e. Comes With The Optional Front Mount Air To Air Intercooler Kit. Has Pipes For Nearly Every Wheelbase Configuration. (ie Short Bed, Long Bed, Crew Cab, Tahoe, Denali, Escalade, Yukon) Fits All Ls Engines, 4.8, 5.3, 6.0. Etc. Front Mount Intercooler Mounts Between Frame Rails. Comes With An Braided Oil Feed Line, High Pressure Rubber Return Line, Sts Oil Pump And Wiring And Install Manual.Also included is a new in box autometer boost gauge, used late model 6.0 exhaust manifolds with new gaskets and orings, and a brand new GM export model ypipe without convertors. Kit ony needs Outlet Pipe And Clamp To Be Complete. Chris At Sts Priced These Parts For Me At Under 60 Bucks. You Will Need Larger Injectors, (42lbs For Most Applications) And A Upgraded Fuel Pump Or Pump Booster And A Good Custom Tune. I Highly Recommend Allen At Nelson Performance To Tune. He Does Great Work With These Turbos On Ls Trucks. Entire Kit Is About 4800 New So This Is Half Price. Dont Need Any Parts To Trade But Thanks, I Really Am Looking For The Cash. Phone 830-486-9682
    2005 crew cab, new crate lq9 with comp 212/218, 558/563 on 115 cam, 80mm t.b. coated long tubes, off road y, flowmaster cat back, dynomax bullet, ngk plugs, msd wires, k&n cold air kit, 4.10 gears, auburn pro lsd, transgo shift kit, nelson drive tune, trailblazer i-6 torque convertor, anzo lamps, ss front bumper, z71 tahoe rear bumper, debadged, kenwood touchscreen with headrest monitors, JL components, coaxials, sub, 5ch amp. bell tech 2/4 drop. 22x10 ss wheels with 285/35/22 bfgs.
