i finally got mine lined out i think, i cant believe u dont have a wideband G!!!
Mine use to read all over the place until I adjusted the output rate to 1/6th of a second. Now it stays fairly steady. The LC-1's can read fast enough to pick up individual exhaust pulses and show lean and rich spikes.
Another issue you might be seeing is the o2 sensors cross counting. The factory sensors only read around 14.7 so the factory ecm makes the afr go rich to lean at a fast rate. This allows it to cross the 14.7 point several times a second in order to adjust fuel trims. Your LC-1 may be picking up on this also.
99' Silverado RCSB Z71: 5.7L Iron LS1, 11.2:1, Custom EPS Cam, Ported 862's,Ported TB, E-Bay Cold Air, E-Bay Long Tubes, Dynomax X-Pipe Exhaust, Electric Fans, Innovative LC-1, Self Built 4L60E, Circle D Pro Single Disc, 4:10 ValueTrac
It comes with a serial cable and the LM Programmer on the CD for it. The instructions for the procedure are also on the CD.
