Page 2 of 6 FirstFirst 1 2 3 4 ... LastLast
Results 11 to 20 of 58
Thread: New Numbers!
  1. #11
    Pittsburgh, PA
    curious to what was the old combo's numbers?
    2014 Xsport- 3.5 Eco boost
    412 Motorsports
  2. #12
    Spring, Texas
    When I had the stock 5.3, stock intake, T60 and 9psi, I made 422/411.
    New numbers were with iron 5.7 with 317 heads (8.4:1CR), Vic Jr., T76 and 11psi
  3. #13
    Pittsburgh, PA
    Quote Originally Posted by Sleaper View Post
    what did this combo make on 9psi?
    412 Motorsports
  4. #14
    Spring, Texas
    The new combo made the numbers in my sig at 11psi...sort of. Boost wouldn't stay constant at WOT since there wasn't enough load. I have boost set for 14psi but it never got there. It get's there pretty easy on the street.
  5. #15
    Pittsburgh, PA
    i understand its on 11psi but did you make any numbers at 9 psi? im trying to compare your two setups at 9psi
    412 Motorsports
  6. #16
    Spring, Texas
    The first run only made about 9psi and it was around 410rwhp. It seemed to me that the turbo was just starting to work on the later pulls as it made more boost.
  7. #17
    ryan_prettyman Guest
    you should have no problems making it here is what my 5.3 did on a bad tune and 7 psi front mount T70 all stock internals!
  8. #18
    Was not your tune Allen before you get all mad!
  9. #19
    Round Rock, TX
    why does the hp and tq cross at 4250... Something looks really wrong with that graph... plus its peaking at 4400rpms
  10. #20
    Spring, Texas
    Quote Originally Posted by DBRODS View Post
    Where is it supposed to cross again?
