Page 2 of 2 FirstFirst 1 2
Results 11 to 17 of 17
Thread: nbs cable upgrade
  1. #11
    Plainfield, IL
    Relay for each fan (camaro setup)
    No capacitor.
  2. #12
    Tyler, TX
    frame gound i usually right under the crank pulley on the front, it hould connect to the crossmember
    www.tjc.edu
  3. #13
    Pittsburgh, PA
    i ran 2/0 welding cable. stereo wire isnt designed for the ampacity and heat. Welding cable is much more durable and stronger insulation jacket. Plus the strands are different then the super flimsee stereo stuff
    i have 2/0 from battery to redbox, i have 2/0 from battery to frame, i have 2/0 from motor to frame. I have 8 guage for alternator and have no issues what soever with a 102amp alternator. My battery cable goes from back by roll pan to front of truck.
    i run EWP which draws alot of current constantly ,Efans, stereo and other electric add ons and i never drop below 14v
    2014 Xsport- 3.5 Eco boost
    412 Motorsports
  4. #14
    Plainfield, IL
    i used 2 gauge battery cables from autozone on top of factory stuff. I don't have a ground in the front...that might be the problem.
  5. #15
    Maui, HI
    Big 3 actually works vs a capacitor thats adding another point of resistance... just my 2 cents.
    99 Silverado 1500 4x4 RC 4.8
    4L60E, 3.73, Homemade CAI, 92oct Quik tuned,
    08 Tahoe radiator/fans, Dumped exhaust... summed up one loud pig caller |[226K! on odometer|
  6. #16
    Quote Originally Posted by Maui4x4 View Post
    Exactly. Caps are band-aids for big problems.
  7. #17
    What brand battery are you running?
