Results 11 to 20 of 21
Thread: Tire question
    I was just checking the site, and the ET Street slicks I have for my 16x7 say the minimum is 8". But for the ET Street radiuls it says the minumum rim width for the size tire is like 9.5". The rims I am looking at getting are 18x7 or 17x7. Is this going to seal correctly or am I going to have problems if I end up running at a high mph if I use the tires that require a 9.5" minumum on a 18x7 or 17x7 wheel?
    I guess the question now is, would a 18x8 with a 31mm offset, tuck with a 28.8" tall tire on my 6" drop
    Round Rock, Texas
    Depends on the tire width and rim offset. Is the 31mm a positive or negative offset?
    EDIT: Just the offset will move the wheel and tire 1.25" in/out (depending on offset) from your Cragar's
    Quote Originally Posted by Duct_tape123 View Post
    The 5" cragar pushed the wheel out, the stock escalade wheels are a +31mm offset
    28.8 sounds great for a heavy truck and for a turbo.
    McConnell AFB, Wichita, KS
    the reason for the different minimum wheel width could be the sidewall thickness. the radials could be harder to put on a skinnier wheel?? My roomate has 315/75-16's on his factory 2500HD wheels with no problems at all. i see no issue as long as they fit in the wheel well. gary
    2005 SS AWD, 22" REPLICAS, VOLANT CAI, MAGNAFLOW EXH, 1/2 DROP- NEXT: TUNE, SHIFT KIT, SERVOS, TRU-COOL
    (SOLD)2000 ECSB HARLEY DAVIDSON EDITION. 2''/4" DROP, 20" BUDNIKS, COWL HOOD, MOLDED ROLLPAN, CLEARS, DROP IN K&N, MIT, TAYLOR WIRES, LOUDMASTER EXHAUST
    1991 RCSB S10 355 SBC, 700R4, 8.5" 10-BOLT, 18"/19" C6 Z06 WHEELS, 4"/5" DROP, MAGNAFLOW DUALS W/X-PIPE, FULLY SHAVED W/ CADDY LIGHTS: NEXT-LSX 370/PT88/TH350
    ah yeah I think they will fit too. thanks for the help everyone
    Plainfield, IL
    ya lot of guys run 315's on stock wheels (so a 12.5 tire on a 7" rim) you DO get ballooning, doing it with tall sidewall is dangerous cuz the tire can pop off on hard turns.
    On lower profile tires, it'll be harder to get the bead to seat, but it'll stay that way once it's on. A wider rim will just give you better road contact. Your outer 1/2 inch might bubble out, but lowering psi should fix that a little.
    My cousin has a 81 malibu with a 502 and 2 stage nitrous and he only runs a 10.5 slick on stock suspension...I can't imagine you needing much more then that.
    Quote Originally Posted by oleshifty View Post
    Trucks weigh less in the rear than cars.
    That size was the only size I could find to keep it close to the 28" tall tire, I didnt wanna go to a 26" tall tire and lose any mph
    The Escalade wheels will move in 3/4", so they will stick out as much as stock, you just have an extra inch on the inside because of the 8" rim width.
    Yeah thats what I was figuring too
