Page 2 of 5 FirstFirst 1 2 3 4 ... LastLast
Results 11 to 20 of 50
Thread: Nos
    Augusta, Ks
    Did he do an sd tune? You might talk to him before you take any advice from us.
    2004 Buell XB12s
    Birmingham, AL
    talk to him about it... if something is screwy in your MAF you might not want a dry kit, cant really help ya there without the proper info tho.
    but if your maf isnt working properly then you definitely dont want to rely on it to add 100hp worth of fuel...
    01 Silverado
    Just get the wet kit and be done with it.
    blanco,tx
    Which would you suggest? And where would you find it?
    I am a huge supporter of NitrousOutlet, also. Their BrandX systems are pretty good quality and value priced. They have some full complete kits with heaters, safety switches, RPM switches and all for good prices. Never cheap out on a system, it will cost you in the long run. Call the guys there and get their suggestions, they know their stuff. I would also suggest getting a 15 lb bottle rather than a 10 lb bottle. There are a lot of us that would sell you a used 10 lb bottle for cheap because we get tired of filling them.
    Nitrous Outlet Product Details - Total Packages - Nitrous Outlet Complete Packages
    just do like me and keep 4 of em in the truck
    Nov 2006
    Mesquite, TX
    x2 and i can run a stock 24lb injector because i know how to adjust the pills to get the afr right.
    Also on that note a mildly modded truck can safely pull a 100 shot from the rail without needing injectors...now when you get up above 150 shot then yes you will need injectors...whether its a dry or wet shot either one will raise your IDC's by 10-15%
    +1 on the wet kit, 100 shot would be fine pulling off the rail, might wanna get bigger injectors, virgil(mean05) and greg )redheartbeat) are good with nitrous, ive learned quite a bit about it too, once you get serious about spraying look into a system like mine and virgils or gregs. plate kits are the way to go the "hit" is so much better.
    +1
    But I will say with a 100 you probably won't need bigger injectors...Virgil is sprayin 300 on stock injectors.
    +1
    ...............im spraying a 200 on stock injectors......but me and virgil both have stand alone systems, we dont pull off the rail....
