Page 2 of 2 FirstFirst 1 2
Results 11 to 19 of 19
Thread: Advice on Trailer Purchase
  1. #11
    H-Town
    Whats the downside to wood floors? Was leaning towards wood for cost reasons. Do they just get torn up too quickly?
    Ill look into the bulldog coupler as well, thanks.
    ________________________
    2006 2500HD, RCLB, 4X4
    6.0, 4L80e, 14 bolt
  2. #12
    Wood floors get torn up, will rot eventually, and wood can hold a sharp piece of metal straight up that'll ruin expensive tires
    Oct 2007
    Bandera, TX
    ya, x2 on the bulldog..... my trailer is about 3 years old and the deck is getting rough. wont be long and will need a new one..... im sure if i would have sealed it, might have lived longer.....
    single digit street truck
    for build info
  4. #14
    Tyler, TX
    best advice i can give, is to get one that the fenders don't stick up to high on. If you pull a truck up onto a trailer with tall fenders, you won't be able to open the doors. so try to find one with the deck extending out over the wheels. they are a little taller but not much. I spend about 2 days a month building hinged fender assemblies for that exact problem.
    www.tjc.edu
  5. #15
    Houston
    This guy has the Best Prices on them The Trailer Man dot net he is in Spring, Tx. I have the 18 ft Car Hauler with the Steel Deck from him and had no problem with it. Electric Brakes, 2ft Dove tail, Bulldog Hitch, 5ft Daimond plate Steel Ramps that slide in and out. If he don't have he can built it. The 2ft Dove tail works great for a Tool Box a just put one on it
  6. #16
    phoenix az
    and make sure it has good trailer tires. have seen some trailers with cheap tires and the tires came apart after a few thousand miles or less lol
    1998 chevy 1500 with 6.0/4l80e comp cam, tune, exhaust,
  7. #17
    Wood floor should last 10 years or more if taken care of but then what? Wolmanized 2X12's are not cheap to replace. +1 on the fenders that will clear the doors and REAL trailer tires.
  8. #18
    Mar 2007
    I have an Aluminum Trailer, 7500 Axle, light, and tough.
    Bestpricetrailer.com
  9. #19
    Houston
