YAY WE DID IT!!!!!!!![]()
Im tellin you guys, I did a motor swap on my own so I am somewhat mechanically inclined. That belt was a bizzoch!
http://i121.photobucket.com/albums/o...IMG_2118-1.jpg
1999 Silverado 1500 Z71/5.3 to LQ4 6.0 swap/ CAI/ crappy exhaust/ tuned by COWL327
Put a pair on a supercharged Park Avenue or a V8 Aurora and you'll like this one from now on.![]()
No thanks...
the first time I had to replace one on my old Z it sucked. on the second one after some cursing and scratches up and down my fat arms I remembered I needed to go from underneath. After I remembered what I was doing it took about 10 minutes from getting the belt on to putting everything back together that I didn't need to take off. New truck has E-fans so now it will be quite simple.
Efans make it so much simplier.. takes longer to find tools than do the actual work.
2000 ECSB Silverado 12.5@111
1993 RCSB S-10 Stock- for now-
+ one billion. It's worth the $846 it cost me to run efans to swap the belt. J/K...it is a lot easiesrest with efans.
Counts the fans, the harness, and the tunethat makes it work like stock (didn't mention it adds 30 HP too).
what fans did you go with? thats crazy.
my first efan setup was about $90 for everthing. LS1 Efans, connectors, wire, relays. Made my own harness and i already have EFI live..
few weeks ago i towed a 05 Silverado home for a friend, in return i swapped him my 28" rad and LS1 Fans with harness and tune the PCM for the 34" rad and 34" Fans.
we are putting the 5.3/60E in a 95 RC he bought.
