Results 11 to 20 of 32
Thread: Anyone know of traction aids for these trucks?
  1. #11
    Jun 2009
    Harrisburg PA
    will any of the setups listed improve handleing on turns?
    Wills77
    06 Silverado 5.3
    20's wrapped in Nitto nt420s, airaid intake, k&n, magnaflow duals, custom grill, 2" drop shackles, cowl hood, vette servos, autotek 2000 watt amp and 2 hifonics brutus 12's....
    05 honda trx450r #77
    Fully built MX quad
  2. #12
    Quote Originally Posted by wills77 View Post
    idk i either do really tight cirlcles or a straight line
  3. #13
    Aug 2004
    Magnolia, TX
    stiffer suspension and low pro tires
  4. #14
    El Paso
    What is the over load? One of my leafsprings?
  5. #15
    Quote Originally Posted by otter View Post
    yea its the little short one on the bottom wieghs like 30 freakin pounds.
  6. #16
    El Paso
    Has anyone tried 90/10 drag shocks? If so what is your 60 ft.? I am trying to get my rig into the 1.9s . If I can 60 like that then my truck should run 14.50s here and 13.50s in Oaklahoma. That is with a LS1 hot cam, 3000 stall by Yank and a Nelson tune. What is the fastest someone has gone with a hot cam?
  7. #17
    I'm using them on my ecsb but I still have the sway bar which kind of cancels out their benefits. I'm doing 1.7 and 1.8s all day long, 1.7s on the spray and 1.8s off of it. Truck weight is around 4800.
  8. #18
    Feb 2009
    markham,tx.
    i made a set of caltracs for my truck and it only cost me 45 bucks and my 60 fts. was a 1.67 with a little traction issue but hopefully new slicks will help just my
  9. #19
    Santa Paula, CA
    get a couple of fat chicks for the track throw em in the back...lol
    Quote Originally Posted by sleeper1500 View Post
    Done took 'er down to the Pep Boys an pimped it out.
    03 silverado 5.3L
    H.I.D's, 40 series Flow dumped , CAI, 2in Shackles
    03 Tahoe- C.A.I, magnaflow, h.i.d's...more to come
  10. #20
    90/10's on a RCLB that looks like a 2500? Man, the LB might give you more leverage. Seems like you should be sub-2.0 60' with your set-up even though you're getting good overall numbers.
