Results 11 to 16 of 16
Thread: '86 Chevy Silverado C10 (5.3L/4L65E Powertrain)
Threaded View
    Oct 2005
    Baton Rouge, LA
    Consider this official... :judge:
    I have a few local inquiries about the truck, and it's time for it to go. Maybe I'll miss it, but it's still goin' bye-bye!
    SINGLE FAMILY OWNED!!! I have the title (clean)!!!
    1986 Chevrolet Silverado (C10)
    207,000+ miles on the chasis (but EXTREMELY less on the powertrain)
    FACTORY PAINT redone in 1994 due to GM recall. Paint in good shape considering age of vehicle!
    '90s model Chevy 454 SS Wheels
    275/60/15 Tires (Front 2 are NEW, Rear 2 have ~1,000 miles)
    Rear brake shoes replaced in March '09, Front pads are low (Lifetime Autozone pad replacement)
    Bed mat to remain in truck
    ABSOLUTELY NO RUST, NOR MAJOR BODY DAMAGE! :judge: Contact me for questions/concerns.
    5.3L V8 (from a 2005 Silverado)
    28,000 miles on motor
    Custom (In-Person) PCM Street Tune by Charlie Wheatley (Katy, TX)
    **Last 1/4-mile run: mid-13s @ ~100mph**
    ARP Rod Bolts
    Underdrive pulley
    135amp alternator (ACDelco)
    Comp 224/224 .580/.580 114lsa camshaft
    Comp 7.4 hardened pushrods
    Comp 918 springs
    Ported & Polished Throttle Body
    Modified 862 heads (3-angle valve job, shaved .040)
    Autometer electric gauges
    HVAC controls work, but needs A/C installed (I have functional compressor)
    New Ignition Cylinder
    Innovate Motorsports Wideband w/ Innovate gauge
    4L65E Transmission (BUILT for High Performance)
    Transgo HD-2 shift kit
    Aluminum accumulator pistons (both are new)
    Beast sun shell kit (w/ thrust washer)
    GM 5-pinion planetary
    FLT Reverse input drum
    FLT Kevlar 2-4 band
    Borg Warner 3-4 clutch pack
    Borg Warner forward sprag (29-element)
    Sonnax 2nd gear servo
    Sonnax 4th gear servo
    FLT billet output shaft
    13-vane trans pump
    46-MOD Vacuum Modulator (no electronic pressure control)
    Yank Performance SST3200 Torque Converter
    Aftermarket Trans Cooler (over twice size of stock aux cooler)'
    Aftermarket Deep Pan w/ FUNCTIONAL drain plug
    Custom Driveshaft by Margot's of Baton Rouge
    Richmond 4.10 gear set
    GM 3-series rear carrier (from a '76 Camaro)
    $8k... SERIOUS buyers only! Am in NO desperate need to sell! :judge:
    I will TRY to get an audio clip of how it sounds, but camera of of no great quality.
    Interior (Seat)
    Interior (Gauges)
