Page 2 of 2 FirstFirst 1 2
Results 11 to 17 of 17
Thread: Air Conditioning not getting power
  1. #11
    I checked all fuses and they are good.
    Thanks for everyone's help
    1997 GMC RCSB
    LS6/T56
  2. #12
    anybody else know what I can do
    1997 GMC RCSB
    LS6/T56
  3. #13
    You could just tie into the trigger wire with a switched power wire so that its always on with the ignition. When winter comes along disconnect the wire or put a switch under the hood to turn it off. It's rigging but sometimes its your only choice short of paying $80/hr for the dealer to look at it and tell you they don't know what to do but replace the whole harness.
  4. #14
    Thanks RedHearbeat
    Does anybody know what wire that is and if the compressor would cycle if I do it this way?
    1997 GMC RCSB
    LS6/T56
  5. #15
    Nope, wouldn't cycle. Have you traced all the wires back into the cab? Have you replaced or at least checked the relays that control the a/c behind the glove box insert? Have you replaced the a/c control module on the dash?
  6. #16
    There are relays behind the glove box?
    I thought the only ones are under the hood.
    Is the control module the one with the buttons and knobs for the fan and heat/AC controls? If so I have not replaced it, pretty pricey.
    Is there a timed switch(so it will cycle) I could buy and run it directly to the compressor?
    1997 GMC RCSB
    LS6/T56
  7. #17
    Cycle time is determined by low side pressure.
