Results 11 to 20 of 22
Thread: HD Grille
  1. #11
    GA
    Yea he did but im sure he had to trim the cap and bumper some.
  2. #12
    Cromwell, CT
    [QUOTE=static99;275014
    The hood bolts up and so does the grille. The front frame horns will need to be cut off and re welded 1 1/4". then add your top bumper cap and bolt it up.[/QUOTE]
    why does the frame need to be cut? for the bumper? or is it interference w/ the new grill?
    I'm sorry about all the questions but I've never even seen a 2500hd up close
    -Rich
  3. #13
    Wichita Falls, TX
    The frame has to be cut in order to lower the bumper so the bumper pad and grille fit
  4. #14
    GA
    Yea the bumper pad and grill are bigger than the stock ones. So therefore you cut the frame and lower it to let it fit.
    also if you see in the pics quick posted you have to trim a little of the aluminium under the headlight so the bumper will slide all the way back and bolt up the same. I see he trimmed his bumper also im sure that was easier but i just cut enough under the headlight to not have to cut the bumper.
    Also the 2 bumper brackets towards the corners of the bumper i drilled 2 new holes in those and added a grade 8 bolt to hold it together since the original mounts are higher.
  5. #15
    wichita falls, tx
    yes i used the stock top pad and you just have to trim a lil bit off...no biggie
    Intro Radicalli's
  6. #16
    Missoula,Montana
    So All You Trimmed On Was The Stock Bumper Cap?
    '00 1/2 TON ECSB 5.3L 4L60E
    K&N Filter,Gibson Exhaust,Superchips Programmer,Billet Servos,'03+ Taillights,White Door Handles,Carbon Metallic Grille Emblem,6000K HID'S
  7. #17
    wichita falls, tx
    Quote Originally Posted by DUALLS View Post
    yep yep...simple...i dont suggest using a steak knife....just FYI
    Intro Radicalli's
  8. #18
    Missoula,Montana
    Thanks man.I might have to do this.Everybody kept saying you have to trim on the frame.
  9. #19
    arkansas
    i put the HD grille in my 2000.. i wanted to keep my upper pad and didnt like the looks of my upper pad bein cut, so i cut about an inch and a half off of the lower portion of the grille. it looks tight imo..
  10. #20
    Wichita Falls, TX
    Quote Originally Posted by depriest_138 View Post
    ......... I would think cutting the grille would look way worse than trimming up the pad(that is hardly noticeable)....... but to each his own i guess. just my two cents
