boost
boost
compression should match intended boost level ........... done.
2002 Tahoe 4.8 - soon to be turbo'd - SOLD
1989 Mustang - LX Vert - 351W-TT - 2inches of dust covering it
2012 Raptor - 497rwhp at 10psi
If you aint breaking - you aint going fast enough
most ppl arent sure what they want to be honest. ppl toss a turbo on a stock motor and run X amount of boost and then it mishaps. then they go and listen to the rest and say drop the compression. now they run the same amount of boost as they did before and wonder why the vehicle is a dog. less compression allows for more boost. Heres the key tho you want the least amount of boost as possible. less cylinder pressure the better the outcome. build your motor for most power NA then apply boost but take into account what fuel will you be using, what temps will you see and etc.
you can boost 11.0 all day long but you got to be smart. low timing, good fuel. or you can run meth and little more timing. so many variables.
now with a vehicle with compression off boost will be much more snappier and with compression will spool the turbo faster. low compression motors are complete dogs off boost but once boost applied is when you see it come alive. another thing comes into play is displacment. a much larger motor will be more prone to higher cylinder pressues then a smaller motor. the amount of volume filling hte cylinder is always the factor. my 4.8 can see 19psi daily without a blink of eye on 93 octane only...i have a cam that bleeds off compression and im already low on compression to start. also have a larger intake valve to help all this. push 19psi thru a 6.0 with a ls6 and use only gas with 24* timing and see how long it lasts. that cylinder pressures of the 6.0 will be so much greater then the 4.8 youll lift the heads or detnoate alot sooner.
also in picking your motor setup. dont worry about what psi you run. psi is only a measurement of restriction. the key word here is VOLUME. the more volume you fill cylinders is wher your power comes from. that is why 16psi from this setup isnt no where near 16psi of that setup.
plan a power goal, plan a use of vehicle and take the approiate actions to reach your goal in mind
2014 Xsport- 3.5 Eco boost
412 Motorsports
This is key, you want Flow and Volume high and boost level low. A lower boost level will generate less heat. Less heat means more air molecules in the cylinder and the more fuel you can add to get more power.
If you can make X amount of horsepower at 10PSI, or make that same X amount of horsepower at 7PSI which is going to be better.
Step 1. crus at it.
Step 2. get a hammer.
Step 3. torch it.
412 Motorsports
8:5.1 comp and 30+psi and smile
txstvanwilder: but i got lube so i didnt complain
mean05: he told me a price and i bent over and lubed up
truckinL33: 6'' is not enough, and 12'' is too much
pcmcobra: don't drink and bid on egay...lol
408.Luke: lol im not blowing im investing
