Page 2 of 2 FirstFirst 1 2
Results 11 to 19 of 19
Thread: Transfer Case
    Feb 2005
    San Antonio Tx
    oh so tempting... because i know mines barely leaking and etc... ill let you know mang. itll be a lil bit and being that your in austin even better...
    02 Chevy EcSb Z71, 5.3, Helix Tb Spacer, AEM Brute Froce Intake, Msd 8.5 wires, NGKTR55 IX, B&M 25k Trans Cooler, Hypertech 160, Nelson Tune, Nelson Harness & Ls1 fans, Fully Built tranny, tb2600, 216/224 551/551 115LSA, yeller z06 springs, magnaflow, cut-out, hi-flow cats, etc...
    Bump for a good deal. The only two common leaks are the rear seal (easy and obvious) and the pump clip that wears through the case. Get this one while you can.
    Austin, TX
    I going to try to get a dyno tune at nelson in about a month. I could bring the case with me. PM if interested.
    5.3, E-fans, LPP longtubes w/offroad Y, Dual Magnaflow, K&N Cold Air, 160 thermo, Voodoo 212/218 .531/.531 113 cam, Nelson Tune, 4:11, Built 4L65E, TrailBlazer converter. SOLD
    _____________________________________
    2006 2500HD 6.0L Crew Cab 2WD
    Austin, TX
    Quote Originally Posted by Jermoslin View Post
    Selling an Autotrac 4wd transfer case out of my 01 1500 Z71. Removed because I converted the truck to two wheel drive. Comes with harness and if you want control module and push button switch from dash. $500 OBO. Need to pay for the 4L65 I built.
    $400!!
    Augusta, Ks
    Bump...Great Price
    2004 Buell XB12s
    hey man, since you went 2 wd, do you have the 4x4 cluster, i need one for my 01 Z i have a 2wd cluster but like i said i need the 4x4 as soon as i get the cluster i can engage the 4x4 and if it doesnt work i might need the transfer case
    What is the difference in the cluster 2WD to 4WD?
    Austin, TX
    Ya, they are the same. What's wrong with your cluster that you are trying to fix.
    Austin, TX
    SOLD!!
