i have a competition transgo shift kit
2002 Chevy Silverado LT 5.3L z71 ECSB, Fully Built DMC 4L65e, Transgo 4L65E .500 Boost Valve, Transgo Shift Kit, Billet 1st Gear Servo, 2nd Gear Sonax Super Hold Servo, 4th Gear Billet Servo, Rebuilt 10 Bolt w/ OEM G80 and 3:73's, Dumped Single 3" Spintech Muffler, 3" E-Cut Out
Then you prolly need stock pressure settings in the tune.
which would be 81 PSI right
Don't know. GM doesn't give shift PSI specs just PCS PWM amperages.
I broke 2, just like this...
The second one, I was 1300 miles from home. Need less to say, I have a 4l80e in the truck now![]()
01 ECSB 1/2 ton 4x4 6L GMC
11.03@127
KB Racing Borg Warner S475 turbocharged
how do you guys do this i never had that prob
04 1500 5.3L custom hp tuners tune by myself don have a pic of it yet so hear is my old 01 chevy 5.3 460hp 13.669 @ 116
Heavy trucks,hard shifts,good traction.
