Results 11 to 20 of 22
Thread: G80, how strong?
  1. #11
    May 2006
    Waco TX
    Stupid Question. What is mine? 10 or 14
  2. #12
    10 bolt most likely. Crawl under there and count the number of bolts holding the rear cover on.
  3. #13
    May 2006
    Waco TX
    10. I knew it was 10. and I thought that is how you checked, but I was just making sure.
  4. #14
    Jun 2007
    Ocala, Fl
    the 14 bolt on my SSS is broke. still works but doesnt lock anymore. due to me loaning it to a friend and him spinning out of a grass field onto the road. but before hand it was a very strong g-80 lived 60k miles doing sick burnouts and workin like it should
    96 c1500, stock suspension, stock bottom end, 93 octane, street radial- 1.60 11.5 at 115- on the small stage-sold
    05 SSS 2wd 228/230/80e/fti4k/5,5drop/215shot-sold
    90 350ss... beast build
  5. #15
    Jun 2007
    Mine probly only lasted about 1k after putting the stout tranny that shifted hard ,supercharger ,and cam in .then i went through 4 more before i went to a 14 bolt.Again tho ,i put it too it all the time tho.weight is a USUAL contributing factor also ,ive heard the heavier ext cabs ,shatter them alot easier,and probly getting good traction could be an enemy,bangin second gearr with a good hard shift kit and biten caused mine to go a couple times, shattered ring and pinons .even after i installed the posi unit .food for thought .
  6. #16
    Yea mines the 14 bolt but it just dont like to spin both tires any more. some time in a straight line it will tho
  7. #17
    May 2006
    Waco TX
    Quote Originally Posted by badazzchevy327 View Post
    OK so did the 2wd SSs come with 14 bolt and the AWD SSs some with 10 bolt?
  8. #18
    That's my understanding.
  9. #19
    May 2006
    Waco TX
    Lame
  10. #20
    Jun 2007
    Ocala, Fl
    welll the 2wd have to transfer all that neck snapping power to only one axle instead of two lol
